Hi! I was wondering if anyone knows what adhesive can you use for sticking silicone together with another silicone?
Cheers
Cheers
Only thing I think would work is more silicone!
Curiously I believe ‘regular’ silicone doesn’t work for this? I have used something called Permatex RTV silicone that I got in the US (so no idea if it is available here) to glue the waterproof sheath you get on led strips to stuff as I was told that works but ‘regular’ silicone doesn’t. Maybe you need something like that?
I would try Sikaflex:
https://www.uksealants.co.uk/sikaflex-221-adhesive-sealant-300ml.html
It is great for bonding all kinds of stuff together, would be surprised if it wouldn’t work fine for silicone…
I made a mold from silicone, rtv stuff. I’ll have a look. Worst I just mix more of the pink blob.
I’ve used Stixall to stick the end caps on those (rectangular section tube with a drawstring) and also to stick them to other surfaces.
