I would like to be able to clamp a laptop platform to the side of it for my small 13" laptop (weighing about 1.5kg maximum)…
the side of the box is about 15cm tall, which I think will be too wide for the majority of laptop desk clamps to fasten to… (Also they’re all very heavy).
Can anyone think of some clever clamps/clips I might use to bodge something together instead? Ideally the laptop will be over the case (to stop it toppling the case) and 20-30cm higher than the case.
Just thought I’d ask here in case anyone’s immediately got an idea for a way to achieve this!
A friend just suggested this. I think I can buy this or make something similar, and obviously the downtube tube is easy enough to obtain - so really it’s finding the right clamps to be able to attach a pole to the box, and hold 1.5kg that is the issue…
thanks, these are all good. I think some kind of clamp as above in the inside of the box I can just slip a pole into might be the answer, or the slotted answer that just slips onto the box!
