CNC feed/speed settings?
Hi, I need to cut a sheet of tufnol on CNC
(dense heat-resistant phenolic composite plastic, cotton reinforced, non toxic dust - safety sheet)
What speeds should I use? It is a PCB-like material, and I need to use smth like 2mm cutter, but I didn’t find any settings for this in the library (there are no tools set for PCB). How do I approach this?
@CNCtechs
You’re talking about the desktop CNC?
Yes.
Have a look here:
https://www.directplastics.co.uk/news/how-to-machine-tufnol
Seems high speed, slow feeds are the way to go, and you will want to break your job into relatively short runs so you can hoover out the dust frequently.
