Am hoping to test out CNCing this join, would anyone know the best way to do it? I can’t work out whether the negative would be cut in panels or altogether. I know the piece that slots in would be CNCed in 2 parts but can’t work out the negative!
Second question, does anyone know of a place that would have a 500 mm x 500 mm CNC bed? I realise the makerspace is limited to the small bed, this join is part of a modular box I’m hoping to make but if I can’t find anywhere am happy to just test the join itself at the makerspace!
Thanks so much!! I am looking forward to that being in use, sadly am needing this worked out fairly urgently :(( so might be a case of just using the small one
