Coffee pod machine?
Hello, does the space have a coffee machine? I might have a free pod machine (takes Nespresso pods I think) if the space could do with one/a new/second one. I haven’t been down for a while so can’t remember what is currently there. Cheers
There was a machine donated this year, I think it works despite the coffee pods for it have been dismantled and lost.
If you donated the Nespresso machine I could donate one part reusable pods that could fit it… send pics?
it was me. it came with 2 set of filters for the stainless capsules, if we have one set left we can weld it in place. or get a piece of ss sheet and drill a couple holes.
one of the two small sieves/filters of each are gone :frowning:
If you can find the other set I’ll weld them in place
I’ve a different type of nespresso pods, they probably make a weak ass brew. The one you brought is MUCH better, if we could fix it…
Cannot find the model to look for replacement of the metal sieve/filter. Do you have the model number? I’m happy to buy it and give it to you to weld it in place.
(Cleaning of that cavity will become harder, but we can get coffee machine cleaner, right?)
We’ll have to keep them dry cos the mig has mild steel wire and we don’t have tungsten for the tig head ( or I can braze it at home) . I got the refillable capsules off amazon. I might have some leftover thin stainless sheet somewhere, so we can make replacement. With a bit of cutting and drilling.
will we need a nano-drill bit?
1mm or smaller
i think i saw some new cnc bits that are 1mm or smaller. can that be done on the cnc maybe? don’t know just throwing it out there.
The new bits might not be in the cnc system though.
Yea we have some tiny ones! Will take a look!!
They fit a collet so can be put into the milling machine. I found some 1mmish stainless sheet might need a bit of sanding and planishing.
Hi All, just following up on this. Turns out the machine I was promised has been given away :frowning:
I’ll try find another for us. Cheers
