Hi folks,
Does anyone know what I would need to do/purchase to fit this regulator/inflator onto one of our compressors? Thanks!
Hi folks,
Probably nothing, there are only a couple sizes of quick connects… give it a try
Plug it into the air line at the front of the woodshop on the left as you come in
Thanks Andy and Joe. I tried the woodshop compressors, and the connector on the regulator is much wider than the ones on the woodshop lines. I’ll have another go soon and will try to narrow down specific issues.
The dry airline in the workshop is fitted with high flow rate fittings like the one on your tyre inflator you will probably try to plug connect it to the oily Airlines
