2x ash 485mm X 175mn X 45mm which need to be 34mm thick
4 X maple which are roughly the 450mm X 175mm X 7-9mm which need to be 5mm thick
1x walnut which needs to be a strip of 10mm X 44mm 410mm
Im not inducted on the machines as yet.
Would anyone who can use the table saw/bandsaw/planer be interested in giving me a hand getting this wood cut to size at some point over the next week or so🙏
I would be forever grateful and can supply beer, cake or anything else in return😁
I’ll be around a fair chunk of tomorrow and can use the planer. It requires somebody with a key though so depends on whether a key-holder is about. Not sure how to do the 5mm pieces, I think you’d need to attach it to something else to send it through the planer as I believe it’s too thin.
I did wander about the thickness of the maple “tops”, they are going to get glued to the ash maybe I can come up with some way to flatten one side, do the glue up and then put them through the planer.
This is great, Ill bring the wood in tomorrow, and see what we can do, if we just get the ash cut to size that would be a win
I think you can use double sided tape or something to attach it to a thicker piece (spare ply is good) then send it though the planer. Or just grab a hand plane and embrace the zen
