Laser induction assistant needed for 26 Oct
I am hoping to run a mass induction (9 people) on 26 Oct from 7 to 9:30.
I need 1 volunteer to assess users doing the practical steps at the laser.
Ideally you have been through one of the “Ruby” laser inductions.
However, I will provide training and a checklist for use in the session.
You’ll ideally need to be there from 6:30 to 10:00 to help with setup and shut down.
This is a great volunteering opportunity for those on the path to getting shutter access.
i’ll see if i can get a half day off to come help. I’ll let you know I’ll be driving from croydon btw if that helps as well.
I’m happy to help out again if is in the evening
Hi Brendon, I’m available to help. I’ve used the laser quite a bit now.
I am available!
Hi Brendon, I’m available too!
Thanks for all the responses.
@father
You were the first to respond, but I think you may have thought it was in the morning.
The session is definitely in the evening!
Does that work for you?
If not, I’ll move to the next person on the list.
For the rest, I’ll keep you in mind for the next induction.
We’ll need several more to get through the waitinglist!
Yeah @Brendon_Hatcher i’m ok for the afternoon it’s even better :smiley:
Let me know if you need a lift i finish work around 5ish
Cool. @father is booked!
I’ll send you a private message regarding travel, as your offer of a lift may make things easier.
Hi all. I’m planning another laser induction on 9 Nov (same arrangements as above). I’m looking for a volunteer. Anyone available?
Hi Brendon,
I will pencil this in and keep it free in case no one else volunteers, but if anyone is looking for an opportunity to volunteer in order to get shutter access then this would be perfect for them to do.
Thanks James.
I’ll go ahead and confirm the induction session and we can always switch to a different volunteer.
Hi Brendon, I could help with this one.
