TLDR: I had some odd behaviour with the Mini CNC so be extra ready with the EStop button when you start your job.
I was running a fairly long job milling some brass, everything was going great until the cnc machine just stopped, I hit the e-stop as I thought the bit might be bound up.
I checked everything and couldnt see anything wrong so I tried to re-run the job.
At that point I started having problems touching off on the z-axis, when I hit the start button it seemed like the z-axis would get re-zeroed at a seemingly random height. I was fairly quick with the e-stop so avoided any disasters
I did a full restart of the system but still seemed to be getting the problem.
At this point I should point out that Im running gcode created by FreeCAD so its entirely possible that the problem is related to that.
To check I tried running some gcode I had created previously using v-carve and initially got the same problem but when I re-touched off for a second time it seemed to work fine.
This obviously does point towards a FreeCAD problem but its a bit weird that the same g-code was working perfectly prior to this mysterious ‘stoppage’.
I left a note on the machine with the TLDR on it.
If this problem rings any bells for anyone let me know.
It may be nothing but I just wanted to mention it just in case Ive broken anything and ill drop back in and give it another try tomorrow.
Yes, it is the relay in the tool control! - nothing to do with the machine itself or your job, the relay needs replacing or changing to something else, it randomly cuts out and causes the machine to e-stop. Very annoying, we need to fix it soon!
I had another go yesterday and everything worked perfectly for me
I think z-axis problem was related to the gcode FreeCAD was generating gcode which turned on tool length compensation and the tool table in LinuxCNC has a z axis offset set for some of the tools.
I just changed all of the tools in FreeCAD to be tool #0 and that seemed to fix my problem.
Not sure why this was suddenly a problem for me. It seemed to totally coincide with the random stoppage, but I might have inadvertently changed something in FreeCAD. Ill have another look and see if I can make sense of that.
