I’ve recently moved into a new house with some form of wooden flooring, I would like to remove some of the floor to give me access to run network and phone cobles. Does anyone have any information on this floor
Judging by the uneven plank lengths I suspect it’s solid wood, and judging by the lack of nails I suspect it’s glued. A very nice floor, and probably quite tricky to lift without damaging it. That’s all I can say from photos anyway…
It looks like the flooring I put down in my hallway. Solid oak wood planks but with a tongue and groove. I believe it’s called a floating floor - meaning that you put the planks down on a thin foam surface and leave a gap at the edge of the room allowing for expansion and contraction. You usually put the skirting boards over the top of the floor to hide the gap or put some kind of strip around the edge of the floor. The planks aren’t glued or nailed with this kind of arrangement.
I could be wrong but it is this kind of floor then you may need to remove one of the skirting boards in order to get the first board up and then work backwards.
Yep, agree with Glen. That wide gap shows the tongue, which is not glued. In the same photo you can see where they’ve hacked off the bottom of the door frame to get the floor in under, then done a bit of a bodge job filling it back in. This was probably easier than trying to scribe round the frame in the first photo, where it looks like they only replaced the door stop.
Also, they did a bad job of masking off the floor when they repainted the frames (in an attempt to hide their sins).
I bet your doors are all slightly shorter than normal
It looks like T&G flooring. Some types have the tongue and grooves machined so that they clip together. Some of them have clips that go underneath. Either way, they only go together one way starting from one side of the room and moving to the far side and to take them, you have to do it in reverse.
Basically, it’s a nightmare!
Good luck.
