Reserve 3D printer
Hi leadership team,
How do I reserve time on a 3D printer? Tried clicking on the topic “reserve the space” but I don’t have access.
Thank you
Follow the hand in the pics :slight_smile: at the last step add your @name and say what time you plan to use it - start/end time then save the wiki page. This assuming you have already done an induction for the 3D printers.
Also just to note: if there’s not an entry at your preferred time on the calendar, then that means someone with shutter access hasn’t yet committed to having the space open at that time. As you don’t have shutter access, you can only access the space when someone who does have it is there. Either find another time or check back closer to the date to see if someone has committed to opening it at your preferred date/time.
You can also post in Discussion, asking if anyone with Shutter access is planning to be in during the time/date you want to use it :slight_smile:
Thank you!
Hi Gene,
Are you using a new discourse user name? @Gene_Boyarov1 is not a member and you will be not able to access the discourse calendar. @Gene_Boyarov is the member and has all the access (if it is you). Remember that if you need to use the 3D printer you will need to be inducted first.
Hope that helps
Karin
I think you cannot book it because you are not a member
I was in a wrong profile, thank you! I am now logged in with the right profile and can book.
