Sensor above the table saw needs charging
Hi, the lights sensor which is connected to the unistrut above the table saw needs charging, best way to do it is in situ with a power bank and a micro usb cable.
If you do bring it down to charge make sure you remember to put it back as it controls the first bank of lights over the table saw/tracksaw
It has 12% left so will probably be fine if left until I get back but if someone has time that’s great!
Thanks @lewisss!
Juicing it up now!
